[Pro] Safari 6 Developer Tools?
I’d like to learn more about the Safari 6 developer tools. Are there any online tutorials you recommend?
The best way to get started I think is to pick a page that you know well,
then start looking at the Develop menu items and wondering what they might
do. Select something and see what happens. You may have to reload the page
if nothing happens. Start with the Disable stuff at the bottom. Don’t
forget to de-select what you choose, as it affects all your browsing.
Right-clicking anywhere in the browser window will bring up a contextual
menu with “Inspect Element” - clicking that will bring up some code to
inspect about whatever was under your cursor. Clicking on the lines of code
will visually highlight the page…
Explore! :wink:
Sounds like how I learn most everything. :slight_smile:
As someone once said, the best gift we can receive is a curious mind. :slight_smile:
