Does anyone know how to save the freeway fiiles so they can be seen on a pc. I looked at it in my browser and copied the code and saved it to a flash drive. Later I tried to open it on a pc and view it. There was only the code and it would not display when I opened it in the browser.
If you go to File > Upload and choose File Copy as the Upload method, you can create a folder with all the HTML files and other resources to preview the site. You can then copy the entire folder to your flash drive and open “index.html” to view the site in a PC browser.
When I saved the file like that and tried to open it it worked fine. But
later I saved it to my sd card and tried to open that same file from the sd
card and it did not work.
On Oct 7, 2010 1:36 PM, “Katie Wagner” email@hidden wrote:
