Did a message pop up like “overwrite existing file”?
If not, the file sunk into the depth of your hard disk …
You may find it command+spacebar → Spotlight
Nothing like that. The fact is that the problem doesn’t come out every time I save. In fact, I published several sites, but now… I tried looking for the file .html as you suggested (cmd+space), but my HD told me it does not exist…
