Hi can anyone help me, i’ve been struggling for a few days trying to get script accordian to work, i can’t use moo tools as i have carousel on the pages.
I’ve followed Walters walk through here but still no joy.
Can you post a page somewhere so we can see what you’ve done so far?
Which part of the layout is how you want it to be? Could you add some
simple captions in floating yellow “sticky” layers so I can get a
sense of the interaction you’d like to have happen?
As I’ve said before, the current iteration of SA is quite limited –
by design – and is not that ideal for navigation uses. In particular,
it can only be set to load with the first element open, or all
elements closed. There is no support for any other state on page load.
On Feb 12, 2010, at 6:11 AM, Peter Walsh wrote:
Hi Walter,
link to what I’ve done so far with the accordion drop down menu.
also on page is how i would like it to work.
is there anyway that the projects drop down menu will stay open when
you click on another header?
thanks for all your continued help and development in freeway.
