hi waltd,
could it be that the latest version of scripty accordion (0.8.2) is not compatible with freeway 6.0.6? i’d like to use this action for a vertical menu (img as trigger elements and .p as show/hide) in my project, but it just doesn’t work …
Can you please make a single-page document showing the problem and send it to me off-list? I’d like to get to the bottom of this. I have tested SA in 6, and it seemed to work just fine.
On Mar 25, 2013, at 5:40 PM, purity wrote:
hi waltd,
Select each of your graphic heads by clicking in the area below it (in the parent HTML box) and using the arrow keys to get the cursor directly to the right of the image, then press shift and left arrow to select it with a text cursor. In the Inspector, click on the (T) icon to open the text style inspector. On each of the images after the first one, there is a spurious style that has attached to it named .menusub. Remove that by clicking on the little (-) that appears to the right of its name when you hover over it. Once you do that to all of your inline images, the Action will work again.
thanks a lot for helping me out waltd! now it works. one more question to this menu: is there a way to get rid of the spaces between the images?
i also use the scripty fader action on this page(s) for the headpicture that should “change” between 12 instances (i used the action as described), but it also didn’t work. in this case i think, i couldn’t do that much wrong … (the pages are all with wy (php)).
thx for your very kind help again
ray
