[Pro] scripty accordion
I am trying to get this action to work. No luck. I have followed the instructions sheet from ScriptyAccordion over and over again. The closet I can get is just having one h2 head show and nothing else. clicking or rollover don’t seem to work either. Any thoughts? I have about 10 heads with copy to get onto a page and this seems a perfect way to do it. If this doesn’t work is there another solution or am i toast???
Not sure how you missed it (if you posted from the Web) but you have to post a link so we can see what you’ve built. What you describe is not how this usually works – it’s a very simple Action, and it doesn’t take much to get it to work. It does require a particular layout, and that is explained in the example.
