Hi all. I have a scripty accordian, on an existing site which worked perfectly well in 5.5 but not in 6.
I had no idea it stopped working until I saw it while looking over my sites. I figured it was the new HTML align choices in 6. I wish Freeway would have sent a memo about this new change. as I am sure all my existing sites have problems.
I check one other site and the artist logo last name was gone until I went back and changed the align to flexible. I tried the same tactic with the script accordion but to no avail
here is link http://huntspetshop.com/huntspetfaqsb.html
thanks
C
For some reason, the “show a particular item expanded” control is failing to write part of its code to the page. Could you try clicking on that picker and changing its value, publishing, and then change it back to what you want and publish again? I see the error in the JavaScript, but the Action is supposed to have fallbacks for this very thing.
thanks
C
Change None to any number. Publish and look at it in the browser. See if that item is popped open (and the rest of the script works). Then change it back to None and see what happens when you publish again.
GREAT!! Walt
that did the trick I set to the None to 1 and the first answer is visible , although I would prefer that no answer appears unload… Its confusing I think
Is it possible to have a clean list of questions without any visible
