Hi
I’m sure this has come up before but I can’t find it in the KB or List. I want to put a small graphic image to accompany each text block, e.g, a football to go in the the ‘football’ bit and so on. I’ve tried ‘insert’ next to the bit of text to use the image, but it comes on regardless, even when the item is hidden.
Is there a way I can get it to work with the scripty function, or is this not possible with this iteration of SA?
If you make the image an inline image within the paragraph of text
that you show, then it will work just fine. You can use negative
margin to float that image out of the text box, if you want it to look
that way. Double-click into your text block so you see the flashing
cursor, then Insert / Graphic Item and import your image. Set it to
align left or right as you like, use margins and such to control how
it attends to your text.
Make sure you are using the latest version of SA, there have been some
improvements in the area of code that governs the collection of child
elements.
On Feb 24, 2010, at 10:53 AM, thetribe wrote:
Hi
Thanks Walter, and for all the support you give me and the others on the list.
all best wishes
Dick
On 24 Feb 2010, at 16:03, Walter Lee Davis wrote:
If you make the image an inline image within the paragraph of text that you show, then it will work just fine. You can use negative margin to float that image out of the text box, if you want it to look that way. Double-click into your text block so you see the flashing cursor, then Insert / Graphic Item and import your image. Set it to align left or right as you like, use margins and such to control how it attends to your text.
Make sure you are using the latest version of SA, there have been some improvements in the area of code that governs the collection of child elements.
Hi
