Hi all,
Even the downloaded version from Actionforge doesn’t work. Is there a solution?
Thanks!
Paul
Hi all,
Thanks!
Paul
It seems to work just fine here. Can you please elaborate? What have you tried, and what happened that you didn’t expect. Here’s what I just did, and had the expected results:
On Mar 18, 2013, at 8:21 AM, paulvw wrote:
Hi all,
Thanks!
Paul
Thank you Walter. I found the problem… The h2 option was missing in the style sheet… Aaaajjjjj…
Working now!
You can use any block-level tag (as long as it is different from the one used for the paragraphs) that you choose. You set it with the Trigger Element picker.
Working now!
I see… there are more options… I used Mootools before… ScriptyAccordion is still a bit new to me, but indeed, very easy to work with. Thanks again!
