finally my SciptyAccordion works fine. But now i want a title and image as the trigger. This works so far.
But i want the title to the left and the pic to the right.
To do this i would need to set up a table, right?
Now, apparently ScriptyAccordion does not work with tables… So there seems to be no way to place the picture and title this way. What do you think?
If you place the image at the beginning of the line of the title text,
then click once on it and set Align: right using the Inspector, you
should get what you want without any tables. The entire thing – words
and picture – will be clickable.
On Jun 17, 2011, at 12:15 PM, matt wrote:
Hey
And it works - the only problem now is, that the title jumps up. Is there any kind of mix for the Alignment of the Picture? A right and sub mix would be perfect
