[Pro] Scriptyfader not working
I’ve been updating a page on our website that had a Scriptyfader action on it. It doesn’t show in now ‘Preview’ and didn’t upload - it should be to the left of the text, aligned with the top of the first line.
Any thoughts on what I’m doing wrong?
(Freeway Pro 7.1.3)
Your div “Phoenix” is further down the page. Make your browser window taller or turn of javascript and scroll down.
I suspect all other page elements (that are all) set as tables are making this div appear below everything on the page.
Use the CCS button or change each item to a layer in the inspector palette.
David Owen { Freeway Friendly Web hosting and Domains }
http://www.ineedwebhosting.co.uk | http://www.PrintlineAdvertising.co.uk
(Freeway Pro 7.1.3)
LE16 - Our work
Thanks for the swift reply, David. Didn’t initially see it all down the bottom of the browser! I couldn’t get Scriptyfader to work in place, so I swapped over to ‘Sequence Timer’ instead, which appears to work fine now.
Thanks again of your help.
