At the bottom right of the home page, there is a link to view testimonials.
When the link is clicked, you get a box similar to scriptylightbox (darken out of the main site) effect but this has a scrollable text window within, which probably contains html body text.
Is this possible from within Freeway. if so your help needed to produce please.
In the Site Preferences, be sure that Use External Stylesheets is on. Then on the page you want to have appear in the lightbox, apply the PHP Make Insert Page Action to the page. Back on the page where you want to show the link to open this lightbox, do one of the following:
Draw a graphic box to act as the trigger. Click once on the box, find your page in the link tool list of pages, and set the link. Then, while that box is still selected, apply the ScriptyLightbox Action to the graphic box.
If you want to use a text link instead, then apply the ScriptyLightbox Action to the HTML box containing the link. Note that all links inside that box will be modified to use the lightbox, so best if there is only one link in the entire box. Again, make the link in the usual way to the page you prepared with the PHP Make Insert Page Action.
That’s it, no step 3, etc.
On Oct 28, 2011, at 1:50 PM, Mike Thornley wrote:
Hi All
Please look at this link, this explains what I need help with.
(sorry not advertsing)
