Neil1
(Neil)
November 30, 2012, 10:28am
1
Hi,
Just working through my site and noticed the ScriptyLightbox2 ‘close cross’ top left has vanished off all my images it’s applied to- both in preview mode and when uploaded to the site - does anyone know why?
Neil.
What version of the action are you using?
I dont see the path to the closer.png being declared
Version 0.8 is available if you dont have it already - it allows you decide which corner to have your closer.
If you are on v 0.8 then remove the action, publish the page and reapply.
Neil1
(Neil)
November 30, 2012, 11:05am
3
Hi David,
Just checked and I’m using 0.7.4 - I’ll update and get back to you ASAP this morning as soon as it’s done to let you know.
Thanks for the fast reply, really appreciate it.
Neil.
Neil1
(Neil)
November 30, 2012, 11:28am
4
Sorted. Upgraded to .8 and all is well.
Would be a nice feature in the future if the user could close the image by clicking on it / off it or pressing ESC, as well as the cross button.
Thanks for your input David, appreciated.
Neil.
