Hi is there a way to decrease the line height in the far left menu (top box) - I am using h6 for the trigger element and para for the hidden text? As you can see the h6 separate from each other way too much? I would ideally like it looking like the box below it?
You can create a style in your Styles palette for h6, and set space before and space after to whatever you like (or 0 if that’s how tight you want it to be). Just follow the directions for making a Tag-only style: http://actionsforge.com/articles/view/9-tag-only-styles
