Can any one advise me how to install a vertical scrollbar on the side either to a new page, or on all pages including master.
I need to create a stock list, that scrolls down.
The browser will create a scroll bar if the page is taller than the window. Are you looking to create a separate scrolling area within your page, with its own independent scroll bar? If so, just draw an HTML box, and while it is highlighted (corners showing) look in the Inspector for the Overflow setting. Change this to either Scroll or Auto, and if there is more content inside the HTML box than will fit, you will see a separate scroll bar on the edge of that box, visually similar to an iframe but actually (at the code level) part of the current page.
Thanks for your help and quick reply, I extended the page length, and added stock further down the page, and as you said scroll bar was there
Regards
