[Pro] Scrolling Content
Hi All,
01 - I stumbled across this example from Walter of a very cool scroll bar. Does anyone know if this has been turned into an action that works with FW Pro 5.5?
http://scripty.walterdavisstudio.com/scroll/
02 - Does the scrolling layer suite offered at actions forge play nicely with FW Pro 5.5?
As to #1, no, it has not. I have never tried using the Action you
mention in #2, but I suspect it works fine (as in not conflicting with
Prototype) since it’s ripped from a DynamicDrive script and thus has
everything coded manually. The only possible pit-fall awaiting you is
if that script uses an unindexed for loop anywhere (geeky thing, but
Prototype really makes that short-cut unusable). The only way to know
for sure is to try it.
On Oct 29, 2010, at 5:05 PM, TeamSDA wrote:
Hi All,
Hi Walt,
Wow, #1 is a little over my head… Sounds like I have to put put some scripts on the server manually. Can these be set up to pull from google? We have done this with another manually entered feature that requires scriptaculious and prototype.
Also sorry if my post was not clear. Questions #2 was a separate inquiry regarding the scrolling layer action at actions forge as a stand alone action. Curious is if has any issues as it as not ben updated since 2008.
Thank You, Team SDA_Dave
