[Pro] Scrolling layer question
Hey all
hope all is well…
ok here is a small question I have long wanted to ask. I have a scrolling layer with text. Regardless of aligning text justified or left, there is a cut of on the word on the right of every sentence. I know there is a simple solution but I have not figured it out yet. Please help
Thanks as always
C
If you add some padding to the box with the text in it that should do the trick.
Hey Dave
you beat me to it I was going to post back that I figured it out and added padding… I am a little dense thank you good??
C
You can’t be dense if you worked it out for yourself.
Sorry it took 2 days to answer a simple query.
Dave
no worry
I get so much pleasure pulling my hair out figuring a simple problem. I continue to do so loving Freeway all the time. I have been able to make interesting websites albeit no the norm.
Thank as always for your continued help. I am sure I will come up against a road block soon enough. will keep in touch teach!
C
