If you look at the example, the page scrolls at a different rate to the background images.
I understand this is a fairly common and well known feature in modern websites, is there a way to achieve this in freeway?
thanks, downloaded it and had a look and it works well. I just have no idea how to apply it to my own site. when i preview your file in the browser the background off the various elements are shades of green etc and i have no idea how or where to change that, not sure where to upload images as the background. just very stuck.
here is another example http://rapunzelelmusical.com
this uses jQuery and obviously built in freeway
its not for the fient hearted though so if you donβt know how insert bespoke jQuery code and how to write css then it may not be an ideal solution
max
max
Iβd just like to be able to put one parallax scrolling item on one page of a site, nothing crazy like that rapunzel page
