Hello Freeway community, i have one questions:
I use Scripty community in this site: http://www.direkta.it/
in the “corsi” page> click on the first link for example: http://www.direkta.it/Corsi/corsoannualemag1.html, i use the action to te box on left.
Initially it is working properly but then stopped working without changing anything.
This action work correctly in Freeway 7.1.1???
Has anyone had this problem?
Help me!!!
I’m not a hundred percent sure, what you’re referring to, so this is just a guess:
Scripty(Actions):
Are using Scriptaculous/Prototype as JavaScript Library. But on your page, you use jQuery Library as well. As a result, both will enter the door the same time - but only one will win (sometimes even both stuck).
Which will mean:
Avoid mixing them.
Either you need a so called “no conflict” for jQuery (which I’m not really aware of) or - which is the one I prefer - use a jQuery solution (Slider, Carousel, Accordion, Lightbox …) - or think the other way round and try to find a “Scripty” solution for your current jQuery effect.
