In InDesign if you have more than one object occupying a space, you can hold down the Command key and every time you click you’ll select a different object in that space.
Is there anything similar in Freeway? I tend to “loose” objects under things that no amount of clicking can highlight. I try the send backwards and send to back commands hoping eventually the lost object will be selectable, but I cannot get either command to do anything.
Right now if I loose something I have to tear up the layout to dig it out, which can be a lot of work.
Use the navigation list on the left hand side. If you create an item and give it a unique name then you can select it there - it shows everything in their layer order. It’s good housekeeping too.
Thanks.
Update your subscriptions at: http://freewaytalk.net/person/options
RLA - INDISPENSABLE IN WHAT WE DO
part of the mission
RLA is a trading name of RLA Group Ltd
Registered in England no: 3679160
If this email has found you by mistake, please do not share or reproduce any of its contents as they may be confidential or contain material subject to copyright. Instead let us know and delete the email immediately. This email does not necessarily represent the views of the RLA Group. Please consider the environment before printing.
Nathan, thanks for the response, but I have a terrible time quickly recognizing something out of a long list, especially one that is not alphabetical. I’m really hoping for a simpler, quicker option, but thanks for mentioning it!
Command-option-click on the stacked items, and you’ll cycle through them. Shift-command-option-click and you’ll select all of them one at a time (each click adds the next item down in the stack to your collection).
