[Pro] Send Form and IE 9 issue
I created a Send Form page in Freeway Pro 6.0.1 which seems to work on several browsers on both MAC and PC. However, the light gray pre filled text in the text areas does not show up in Internet Explorer 9 running on a Windows 7 PC. The form functions properly if you know what to put into those text areas. It works correctly on Firefox and Chrome on the PC, and on Safari, Firefox, and Chrome on the MAC. Any ideas of a solution for those who will be using IE 9?
Thanks - Ted
http://www.tampabayapparel.com/quickquotepage.html
IE9 doesn’t properly support Placeholder attributes - http://caniuse.com/#feat=input-placeholder
Treat this as an embellishment and don’t rely on it in its entirety. Add text labels to your fields too.
Thanks, Dave.
