The contact form (see link below) is failing. It immediately forwards to the “error” page when submitting.
I have used the “send form” action without problems before.
Tried applying the “send form” action to the item and also the page with the same results. Have tried various combinations of settings within the action settings/pane.
I’ve also searched forums, knowledge bases etc with no conclusive results. Could it be to do with the “GoogleMaps” action on the same page and, if so, what can be done to resolve the conflict?
I can’t say what’s wrong with your form, someone else will need to step-in, but PHP 5.3.2 is outdated. Even v5.4 is getting long-in-the-tooth. 5.6 is a safer bet, or 7 if that’s an option.
Office (Chicago): 312.212.3955
Have you tried the PHP Feedback Form instead - do it on an otherwise blank page and set each error to its own page ie server error, not in domain, email error etc.
If PHPFF works then SendForm should too and if it doesn’t then report back which error page you end up on.
If you dont get an error page then try using a recipient email address for the server you are testing on.
Can anyone tell me what code the “Send Form” action generates
As far as what sort of code the SendForm action uses - it generates a php script which you will find called FW_SendForm_contact_twoLeft.php in the same way that the PHPFF action works
Thank you for the suggested trouble-shooting workflow.
I’m just about to download “PHP Feedback Form” from ActionsForge. The download page says it is compatible with “…Pro 3.5, Pro 4, Pro 5, Pro 5.5, Pro 6”. My version of Freeway is Pro 7.1.2. Is that likely to be problem?
Franz.
