Hi, I’m working on adding the SEO to a site I’ve built, can anyone help answer the following-
Should I add descriptions and keywords metatags to just the home page or the masters giving them all the same as the home page? Any tips would be most welcome.
Regards
Steve
Individual titles, description and keywords for each page - These meta tags should be unique to each page they appear on.
Titles and Descriptions are very important. Keywords less so. But all should stick to the rules and be keyword rich and work with the actual page content.
If you haven’t already, it is good to read these sites.
Austin Wells Design Limited
One Elmgate Drive - Littledown - Bournemouth BH7 7EF
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.uk
Member of NAPP | Zen Affiliate | Dorset Business Member | YEC
Facebook | Twitter | LinkedIn
Regards
Steve
Regards
Steve
continuous forwarding the sitemap
to search machines.
used also mistakes in writing as keywords
description etc. which is a very good trick.
Example:
Lots of people writing “breif” instead of “brief”
into search fields. Look for popular mistakes
in your business wordings. Could be “grahic design”
instead of “graphic design” …
Using the Page Title text “my product in mytown” in the similar arrangement to a search is more likely to be found than “mytown my product” ~ But only to those googling “my product in mytown”
Both have keywords and both are key phrases. You need to consider which is more important.
Google will look at the words in your page title, your H1 headings, your file name and page content to determine what it feels are the keywords/phrases it deems important
You can go some way to push google in the right direction.
David Owen { Freeway Friendly Web hosting and Domains }
