If you are sending out a newsletter yourself, then you can use a simple form and apply the PHP feedback form action this will capture the email address - it will come into your inbox.
Just have the following fields in your form:
Name
Email
Submit Button
If you are sending through a service such as MailChimp then it should give you the form code that you can then paste into a ‘MarkUp’ item on your page.
Are either of these options the route you are taking?
Well, we are redoing a site and I noticed they had the newsletter sign up. I did more investigating and discovered they use Constant Contact and they do indeed give you the code to use.
Can this be placed in a Markup Box, or is there anther way this would be inserted in the page?
Either use Markup box with that box floating as a layer, or use Crowbar Action if you want to insert it inline (as in an inline layout). If you use an inline Markup box, you will end up with an invalid construction – a DIV or FORM inside a P. Also, if you already have a form on the page, you must break out the Multiple Forms suite of Actions. Otherwise you have the dreaded form inside a form, which means the CC form will not work about two thirds of the time, and leave you scratching your head.
