This is getting stranger.
All of the html pages view fine, and I can also see the index.php page but it gets a big black band across it after about 1/2 second or so. I’ve uploaded to my webspace and the same is happening there:
http://www.trevreav.co.uk/PTtest
I have the Webyep init, logon button, loop start, short text, long text and loop end elements added as far as WY is concerned.
Could someone please have a look when you get a spare moment and see if you can work out what is causing the black band which covers the top half of the page?
thanks
On 21 Dec 2012, at 10:18, Trevor Reaveley wrote:
Hi Dave, thanks for the quick reply, I’m obviously doing something wrong here.
Yes it’s all running. I see the test pages for MAMP > Start, phpinfo, XCache, phpMyAdmin etc. and it says “If you can see this page, MAMP is installed on your Mac and everything is working” and it also says both Apache and MySQL Servers are running in the preferences, so all good there. Is there anything within MAMP I need to configure?
So far I’ve tried:
localhost:8888/paultizzard.co.uk
localhost:8888/index.php
localhost:8888/MAMP/paultizzard.co.uk
localhost:8888/MAMP/index.php
and variations of these. All say page not found or similar
So just to confirm how I have it set up:
Applications > MAMP > htdocs > index.php (and all related files including webyep-system)
Once again, thanks in advance.
