How do you apply a shine affect to a menu bar like this one?
http://www.newleafdigital.co.uk/
If you mean the graduated background to the menu - that is done by applying a background image in the CSS settings.
Ya that’s what I mean. I applyed a background to it but could not get the
graduated part. Where is that located in that actions palate?
applying a background image in the CSS settings.David
The image itself is graduated.
Have a look at http://www.newleafdigital.co.uk/Resources/nld-gradient-4.png
Quick example http://www.deltadesign.co/gradmenu.html
Ok. I know what you are talking about now. Where could I get that image
file.
On Nov 30, 2010 8:27 PM, “DeltaDave” email@hidden wrote:
This is one of mine sites. That image was created in photoshop, but you can created your own in any size / colour by using this tool.
Nathan Garner
Creative Director
Austin Wells Design Limited
One Elmgate Drive - Littledown - Bournemouth BH7 7EF
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.uk
Member of NAPP | Zen Affiliate | Dorset Business Member | YEC
Facebook | Twitter | LinkedIn
file.
You could make it easily in FW.
Draw a graphic box slightly taller than your menu and approx 10px wide.
Apply the Fill Master action Item>Actions>Fill Master
Adjust the settings in the action inspector to get the look you want.
Once you have it looking the way you want (Rectangle, linear blend, 90deg etc) then with it selected File>Export to your Media folder (png or jpeg is good).
You can then use the exported image as the background to your menu.
Or this one
Nathan Garner
Creative Director
Nathan Garner
Creative DirectorAustin Wells Design Limited
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.ukMember of NAPP | Zen Affiliate | Dorset Business Member | YEC
file.
And a very good looking site it is!
Ha. Thanks ![]()
Nathan Garner
Creative Director
