[Pro] Shop Actions
I have multiple options for my products. Can someone direct me to a good tutorial or walk me through it…
Using Mals-E.
Have e-buy form set up… need drop down options and a quantity fill in…
Thnaks!
Like this http://www.deltadesign.co/odds/tartan.html
Yes!!! I am a manufacturer…
Based on their choices dictates prices… so add that to your help please!!!
Thanks so much.
You will need to be more specific.
Can you explain how many products you have, how they vary and how is the price affected by variations.
Multiple products with these same choices - width, length, centerpiece, quantity.
Then there are ‘ifs’…
‘If’ this width there are only certain lengths available.
‘If’ this width with this length it is this price; if another width and length it is another price.
Thanks so much again!
You will need to be more specific than that.
How many products, how many variations - what is/are the products
Do you want customers to be able to purchase by the length for specific widths.
We need as much information as possible to determine if this can be done using the FW Shop actions or if you are going to need a PHP/MySql solution.
If you dont want to post these sort of details here then my email address is available in the People section. Click on my name on the Web based forum.
You might want to take a look at the Ecwid.com shopping cart. I’ve found it to be user-friendly, flexible and has the ability to add multiple options.
Bryan
I’ve become a big fan of Ecwid. I’ve used it now both in sites created in Freeway and in RapidWeaver. The setup on your site is almost instant – just paste in a code snippet. And setting up the store on the ecwid site is a real piece of cake. It’s certainly worth taking a look at to see if it meets your needs.
Martin
Bryan
…but it should be mentioned, that some of the “hardcore product combination settings” are not available in the free ECWID version, therefore you need to check if it comes up to each expectations.
It would be worth to try it for this particular case.
But to try out and have a look - I’m with you Bryan and Martin.
Thanks for the assistance. Have you had any issues adding the CSS code to Freeway?
If you question is in regard to adding Ecwid code, it is dead simple. I had never added code to freeway pages before starting to use it. The learning curve is very gentle and the forum is good place for assistance.
Bryan
Thanks so much!
I did a small screencast on how to implement the ECWID Widgets so feel free to have a look on:
http://www.kimmich-dm.de/kdm-factsheet.php?DOC_INST=5
(and a template store as well)
