Hello,
I want to put a shoutbox on a page using HTML markup, but it always appears at the top of the page. What should I do to put it in the middle of the page.
I have no clue what ‘shoutbox’ is but when you want a Markup item to appear in a particular place on your page then you would use Insert>Markup Item which results in an item which you would then resize and position where you want it in your layout.
