After putting your pictures in show case how do you put them to the like so you can view them on the page?
You just click where you wanna place it and go to the freeway menu…
INSERT > ACTION > SHOWCASE GALLERY
I tried that but its just has a box that only say show case box shows up. I want to put them in 1 link that can lead all my photo galleries etc.
Youre not completing the process. after “the box shows up” click o the box
once to highlight it and make sure you action panel is open (if its not go
to WINDOW>ACTIONS and in the actions panel you can select your gallery and
its type and set the image setting etc
Ok I now have the action window up now looking for the holders is showing a gray I can’t select
The goodly God-fearing folks at Softpress have created a detailed guide on
creating, configuring and inserting a showcase gallery from start to
finish. You can find it here
Scroll down to the section called
Showcase Action Reference Section
and follow the steps.
Glyn
Thanks Glynter I did all of that. and its not doing what the instructions are saying. but thanks
