I have set up four stacked graphics per the instructions on the Freeway site for “Target Show/Hide Layer Action”. I have the Page Action set for Sequence Timer set up per the instructions as well. The graphics are set for 3 seconds with a 1 second fade and the timer is set up to loop. What I get is four images without the fade between them and no loop. What’s going on?
Ok. I reversed the order of the graphics to have #1 on top and #4 on the bottom and now I have the fades. However, I still cannot get the damn thing to loop.
Ok, Guys. After a lot of trial and error I discovered that if I number the Graphics 2-5 and set the Sequence Timer to “Yes” for targets 1-4 it works. What is going on here???
