I’m building a short slideshow of 12 images on the homepage. Using the show/hide layers action, plus a page action as per the tutorial “Moment 11”. I followed the instructions exactly but the issue is that the images do not dissolve into each other, but fade off and then fade in. The tutorial shows each image dissolving into each other. What did I do wrong?
Have you set the action settings on all your images as
Initially: Hidden
Restore: Sticky
Effect: Fade
Duration: 0.5
And what speed did you use in Sequence Timer
Dave thanks. It was the sticky that got me. How could I have missed that. Thank you so much for the help. BTW I’m from Glasgow and living in the USA
Where in the States are you Peter?
