However on the web yep version the image does not get placed in the html item I have drawn out for it but below it. So I have had to place the the item in Freeway above where I want it. On the link below you will see one coloured blue to make it obvious and this can be seen on the FW screen grab further down the page. If the items are left with no color fill there is no visible problem.
But why should this be and is it likely to cause problems elsewhere ?
Not on that test page/example but I would like to on this page which has most of the elements in place except I have not attached a web yep to the show hide layer images as they jumped even more out of line.
All other elements are Webyep elements apart from the banner and title
Hi Richard it’s a little hard to figure out how this element / page has been constructed with freeway but could you try to add some attributes to the webyep image to see if that does it.
Click on the webyep image and in the actions palette, click on the Extended button and write this:
style="position:absolute; top:0; left:0px;"
Then do a full publish. From the quick online editing I did, I managed to get the webyep image to go into the correct position.
