When I create a new gallery with latest version of Showcase and Freeway Pro 5.6.5 I keep getting a Javascript error related to path name. I’ve started from scratch a couple of times and keep getting the Javascript error.
When I open an older published site with a showcase gallery everything works just fine.
Any ideas…
I have discovered what the problem is stemming from. It was the naming of the files to incorporate into the slideshow/gallery in Showcase. Apparently some files were named with a / instead of -, causing the javascript to look elsewhere for a path that did not exist.
This thread can be closed…
-Wayne Williams
A good point to stress when naming any files to be used on the web.
Stick to alphanumerics ie (A-Z, a-z, 0-9) and _ underscores and - hyphens
