I have a problem with the galleries showcase, do not display correctly
http://produce.mx/btcdemov5/congresos2009btc.html
What is happening here is that the gallery is actually outside the area of it’s parent container, which is set to overflow:hide. I’m not sure what would cause this, but double-check on the positioning settings for the item.
thanks, but in settings is overflow:visible… i dont know what happen.
i uncheked layer and fix it.
