Hi all
I am making a showcase gallery and would like no space between thumbs. Is this possible?
thx
Hi all
thx
Hi Carla
http://www.deltadesign.co/odds/showcase-thiumb-spacing.html
hey David
I am trying this now. I must be doing something wrong hm let me try again
ok your gonna love this Dave
I put code in correctly, tried to preview and it would not load, I tried in firefox, no loading preview. I took code markup out and preview worked.
so what does this mean??
I tell you this 6 upgrade has been a ball of laughs!
I would like to achieve this look… is it possible? with showcase
ok I shut down and restarted. it must be a glitch the preview works but spacing is same. I have this code and called my gallery scccontainer
#sccontainer ul.fwShowcase_thumbs li { margin: 0px !important; padding: 0px !important; }freewaytalk mailing list
You are going to have to post a link so that I can see where you are going wrong.
You can send via email if you don’t want it public.
will do
OK
The thumbs are being generated as square containers at 100px x 100px so try the following instead.
<style type=”text/css”>
width: 66px !important;
</style>
You may have to change the insert point for the style code.
it appears that showcase is adding style info after the code we inserted.
Try inserting the markup in the After slot instead.
