Is there a manual, or any information regarding how to use Showcase? Thanks!
I can’t say I have come across one. I have found its a bit down to trial and error and once you’ve made a few errors it becomes reasonably straightforward depending on your level of understanding of how it functions.
Is there anything in particular you are looking to achieve? I’m not an expert with it but if I can help then you never know.
