Is there a way to change the layout for Showtime so that the thumbnails are displayed above the main image instead of below?
Great site, thanks to everyone who contributes, it’s a great help to a new user.
This can’t currently be done directly in Exhibeo but it’s pretty
straightforward to edit after exporting. If you’re exporting to HTML,
you’ll want to be looking at the body section. If you’re exporting to
Freeway, right click on the export and choose Show Package Contents,
then open the file ‘body’ in TextEdit.
Right near the top, you should see something like this:
Importantly, what you’re looking for is the div with
“xb-showtime_slideshow” right up until the last “” before the
div with “xb-showtime_slidereel”. Select those lines, cut them and go
right to the bottom of the body code.
Just before the last “”, paste what you’ve just cut. That should
be all you need to do, you’re just swapping the order of the slideshow
and the thumbnails. (or slide reel, hence “xb-showtime_slidereel”)
-Sim
