Hi,
Can someone recommend a simple animation software for the Mac to use in Freeway Pro?
I want to be able to import a quicktime movie into the software and have text be able to move.
Hello Bob.
If you want to create simple gif animation I would recommend GIFQuickMaker or have peek at Mac Updates and filter for free animation. For me I use the Anime Studio Pro for creating cartoons. The only snag is the Quicktime mov or mp4 and mpv. Windoze has problems and a few other browsers if not installed quicktime already. Conversion is the problem in the code I think. GIFQM allows you add so many frames of images to make the movement.
