I have an existing client who would like to integrate an e-commerce system into a website I built a few months ago using FWP and Perch. We’ll only need to feature about 20 items.
Which e-commerce solution is the easiest to implement with FWP?
Thanks for your response Simon. Is there an Action to integrate ECWID into FWP or do you simply link to ECWID and it takes over? Would you mind posting an example of how you used it with FWP?
To implement you just put in a snippet of markup code, I’ve just done this for a client but the shop is currently empty so it is a fairly unhelpful blank box. But if you put it in a blank document you can preview it locally (assuming you have an internet connection on)
I had a very, very short view on https://cashiecommerce.com/ these days and it looked promising. The implementing is a simple line of code.
Foxy looks also great, but it seemed a bit complicated and expensive to me whhen I gave it a first view (so I maybe have to give it a second).
ECWID sucks a lil’ bit since they set the free version down to 10 products and “designing” is a bit of a nightmare, cause you need to adjust (and walk through) tons of CSS classes in a real monolith.
Still doubts with all solutions here regarding the EU community laws of ecom that are probably much stricter than the US ones (not sure).
