[Pro] Simple Site Search
Can the results box be put inline? So can grow or shrink depending on the amount of results? If i place the results box inside another HTML box I cant see the mock text to format? Also why cant I use arial!??
J
Inline would be good, although by choosing to display 5 results per page means you have a set size and it’s not too big a space if only 1 result is show.
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
J
