I am fairly new to website building so please bear with me. I am very pleased with what I’ve been able to do with Freeway so far, but I have run into problems using it with third party apps.
I’ve been using a trial version of SimpleViewer to see if I should buy it. I like what it does but I’ve been having problems getting it to load in Freeway (5.6.4). I followed the instructions ( 8 times) on the SoftPress website (http://www.softpress.com/kb/questions/229/Using+a+SimpleViewer+slideshow+in+Freeway) about embedding the viewer but I can’t seem to get it to load the gallery. I get a “Gallery XML Not Found” message on my preview and browser pages.
I am using the svBuilder app instead of the Photoshop Template because PS flattened the png files before saving them, eliminating the transparency and I haven’t been able to modify that with my limited knowledge of actionscripts (I gave it a shot but to no avail). The apparent difference between the PS template files and the svBuilder files is that the swf file is in a folder named “svcore” which also contains javascript and CSS files. I’ve tried a number of different configurations with the files and folders but have had no luck. I can open the swf with Flash Player and it works perfectly but not in Freeway.
I really like Simpleviewer and I think it fits my expanding needs better than Showcase, which I have been using. Any help would be greatly appreciated. (note: I’ve also tried the SlideShow Pro Flash extension but abandoned that pretty quickly). Thanks.
