I originally had (in FW6) the sidebar with the opening times automatically adjusting to the height of the main content by adding, to the div’s extended attributes; position: absolute, top: 0. bottom: 0. In FW7 though this extends the sidebar all the way to the top and bottom of the browser window?
I’m using a negative margin to shift the content up over the top of the Exhibeo Slider here is FW6 but when I update the site in FW7 the Exhibeo Slider goes over the top of the content (though oddly not over the css menu or the googlemap)?
I suppose this is through “missing” position:relative for the DIV #content-top. Try to add via extended dialogue (as you already did for #opening-times-wrapper) position:relative to the #content-top.
With the second I’m not sure - but could be the same issue.
FW7 doesn’t declare the position:relative for the initial DIV anymore. Only if you add (which will mean working in 7 from scratch) something to this DIV, it will be added afterwards.
We had already discussions about this - with different opinions.
First site is now back to working as it should now that I have set the position of the parent div to relative.
If the issue with the second site is again down to the positioning not being declared, I don’t understand why I can’t just set the parent div to position:relative too (but I’ve tried and it doesn’t work). Do I need to create an initial page div into which I add all the content and declare its position relative?? I’ll keep playing around with it.
