[Pro] Site mapper issues???
Hi, can anyone help with this. Last Night i was using site mapper with no problems applying this action, this morning I took the opportunity to upgrade to 5.5.2, now when I apply the action to the site folder I get a message ‘apply the site mapper file location action to a page in the site’ Why is this happening???
Regards
Steve
  1. Apply Site Mapper action to the site folder
  2. Apply the Site Mapper File Location action to your homepage (if you have any sub folders, apply this action to a page within each sub folder)
  3. If you have different specifications required for the site mapper, you can apply those to each page using the Site Mapper Page Option action
This method has been done to make the Site Mapper more stable.
Nathan Garner
http://www.austinwellsdesign.co.uk
FW5 Pro | MacBook Pro | Snow Leopard
Regards
Steve
Thanks Nathan, got my head around this now. One other question, do I have to go back over other older sites and re do the site mapper actions that I used in 5.5.1?
Steve
Nathan Garner
Regards
Steve
Yes you will have to.
Nathan Garner
Steve
Nathan Garner
Regards
Steve
Thanks, are you experiencing the ‘submitting’ window showing green ticks for google etc… but yahoo never ticks, jus shows grey ‘trying’ bar?
Nathan Garner
Steve
Nathan Garner
Regards
Steve
This is a Firefox issue I believe - if you make Safari you primary browser it seems to go through fine.
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
Thanks once again, when i’m next in Bournemouth i’ll buy you a pint!
Steve
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
One last thing. I tried to apply the site mapper file location action to a page in a sub folder and it told me to remove it! Hmmm
Nathan Garner
Steve
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
Is there already one applied in the root directory? The message should say you can only apply one at a time.
Nathan Garner
Steve
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
I have applied site location action to homepage, I have also applied it to a page in each of the sub folders but it is telling me to remove them, is this correct?
Nathan Garner
Steve
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
Hi Steven,
The message says:
“This Action should only be applied to one page”
This is so you don’t have more than one sitemap generated.
Nathan Garner
Steve
Nathan Garner
Nathan Garner
Steve
Nathan Garner
Regards
Steve
On 3 Nov 2010, 9:18 am, BigG wrote:
  1. Apply the Site Mapper File Location action to your homepage (if you have any sub folders, apply this action to a page within each sub folder)
Are you sure the second half of this is necessary and/or even recommended. My experience, so far, is that it is not… subdirectories are mapped without it.
I wish we could get some clarification on these actions from the powers that be… and a response to :
http://www.freewaytalk.net/thread/view/79394
would be appreciated as well. (c;
Just saw this and am also a little confused.
Do I have to apply Site Mapper to a page in all my sub folders, or with the one on the main Site folder take care of everything?
Bob
