[Pro] Site Mapper not generating Sitemap
I have applied the site mapper action to the site folder, not at the initial stage of building the site but later on in the build, and It is not generating a sitemap.xml I have used this on another site and the site mapper action works fine… Is this a bug with the action or a problem with my site? (www.ictlinks.co.uk)
Hi,
Nice site. The action should be generating a single ‘sitemap.xml’ file
for the site and storing this at the same directory level as the
folder it was attached to. So if you attach the action to the home
folder you should find the site map file next to your home page.
If this isn’t getting generated for some reason try holding down the
Control key and selecting Publish Everything from the File menu. This
will force Freeway to rebuild the entire site from scratch and should
force the Sitemap action into, well, action. Please note that this
will also mark the whole site for upload if you upload through Freeway.
If this doesn’t work for some reason please get in touch with the
support team who will look closer at the issue;
Tim Plumb
Creative Director
Softpress Systems
Follow us on Twitter: http://www.softpress.com/tny/064
Join us on Facebook: http://www.softpress.com/tny/063
Looking for a webhost? We love FatCow: http://www.softpress.com/tny/05v
Nice site.
Thank you
That’s what I thought.
Have done this and no success. Have quit Freeway and reopened both with and without the action applied and no success. I tend these days to upload into an MAMP environment before uploading the site. I will try a direct upload if you think that might help.
Will Also contact softpress KB
Thanks Mark
Hi Mark,
Send your Freeway document into support if you can (use a service like
senduIt - http://www.senduit.com/ - if the file is huge to support
(at) softpress (dot) com and someone (possibly me) will take a closer
look and see what the issue might be.
Tim Plumb
Creative Director
Softpress Systems
