hello guys,
Does anyone know why a site is not showing in firefox version 17? Only blank(white) screen when in home page is showing.
thanks for any solutions/suggestions.
cheers,
carlos
A link would be useful.
Hi David,
here is the link
[vc_row gap=”10″ bg_type=”image” parallax_style=”vcpb-default” bg_image_new=”id^35|url^https://www.wildflowerintl.com/wp-content/uploads/2020/06/sec2.jpg|caption^null|alt^null|title^sec2|description^null” bg_image_repeat=”no-repeat”...
Est. reading time: 12 minutes
FF17 doesn’t like your javascript
[19:47:39.513] Error: call to eval() blocked by CSP @ http://www.wildflowerintl.com/Resources/prototype1602packera.js:1
[19:47:39.566] CSP WARN: Directive eval script base restriction violated
[19:47:39.573] CSP WARN: Directive inline script base restriction violated
@ http://www.wildflowerintl.com/:52
Sorry - I have no idea what this exactly means.
Thanks David anyway,
I’ve bee trying to solve this for a while. Do you think if I delete one of the doubled code lines will fix the issue? the ones showing protoype packer.
regards,
carlos
waltd
(Walter Davis)
March 1, 2013, 8:39pm
6
It means that the script is trying to evaluate (eval) a function that didn’t come from the same domain as itself. This script is placed in the page by the fading slideshow. You might try applying the Protaculous 2 Action to the page, which will try to upgrade the version of Prototype to the latest 1.7.1, which might fix things all by itself. You might also try a different slideshow Action.
