Hi This site is undergoing a revamp, but it is not visible on iPhones, no matter what we do - I have been told it is visible on Androids. It works fine on iPad. I have used the page action > mobile redirect on the master pages, checked all is marked on the inspector palette, but still just get the host name. The host company say it’s not them. Any suggestions please?
Caleb_G1
(Caleb G)
February 3, 2014, 9:39pm
2
Elizabeth,
It looks like you are trying to redirect iPhones to http://www.schooldaysmagazine.com/mobile , which is a 404 error page.
Hi Caleb,
I’m not actually doing anything to do that! Any advice on how to fix it? (until it’s all swapped over to Backdraft!)
Elizabeth
On 4 Feb 2014, at 8:39 am, Caleb Grove email@hidden wrote:
Elizabeth,
Caleb_G1
(Caleb G)
February 3, 2014, 10:06pm
4
You said that you the mobile redirect action. What do you have it pointed to? Try removing it and seeing what happens.
This isn’t the mobile redirect action.
I think that you have added some code in Page>Html Markup in either the After or before
Have a look in there for
if (screen.width <= 699) { document.location = "http://www.schooldaysmagazine.com/mobile"; } //-->
</script>
Elizabeth2
(Elizabeth)
February 3, 2014, 11:43pm
6
I meant within Freeway. Page>action>mobile direct. Am I missing something here?
Elizabeth2
(Elizabeth)
February 4, 2014, 12:09am
7
Yes, found that Dave, so I should do ……?
</script>
Either remove it completely or change the redirect to where it should go - obviously not http://www.schooldaysmagazine.com/mobile as there is nothing there.
BTW - I think it is on your Master(s)
Elizabeth2
(Elizabeth)
February 4, 2014, 1:29am
10
correct, it is Dave. Do I remove this code?
Elizabeth2
(Elizabeth)
February 4, 2014, 1:30am
11
oops! just saw your answer - thank you dave!
