[Pro] Site Phone numbers showing as white on iPad/Phone solution?
Contact telephone numbers on a site I have done are being recognised as ‘links’ by Apple devices so they can be touched to dial or add to contacts, however the default style the Apple device applies seems to be white.
So on the site the numbers become invisible on the white background, they are there, but not showing white on white.
Any ideas?
Seems a link style might help, but as they are not html links as such how would I style them?
(FW5.5Pro)
http://sarahhillgardendesign.co.uk/contact.html
Looking at your site code I can see that the default link style is indeed white. Click on the gear icon at the foot of the site panel and make sure that ‘Show items’ is checked. Now select ‘item 1’ on your master page or each page in turn and click on the ‘Item Appearance Tab’ in the Inspector palette (the paintbrush icon). At the foot of the palette you should see a section for links. Here you can define the link styles specifically for the content of the box ‘item1’.
Alternatively you can turn of the mobile number detection with File > Document Setup > Mobile (Freeway 6, or iPhone if you are using Freeway 5.5) and uncheck the Telephone Number Detection option.
Experienced Freeway designer for hire - http://www.freewayactions.com
Thanks Tim you are a star!
