I would really welcome a review of a site I have just completed in respect to optimising, making the site faster etc etc… or ways I could do things better.
The opening times link in the footer goes to the home page where
the times can be found in the sidebar. These are, to me at least, a
little hidden away and could do with either a page of their own or
adding to the how to find us page.
Some of the page titles are quite short and to the point. These
could be rewritten around your core keywords for the site as they play
a big part of driving (no pun intended) organic traffic to the site.
The title for the location page, for example, is simple ‘Location’.
Change this to ‘Locating the Grosvenor Motor Company - specialists in
BMW and Mini servicing in the Reading area’ and you should see your
organic ranking increase around keywords like BMW, Mini, Reading etc.
Consider adding tooltips or some visual indication to the five item
icon menu to the right of the main image so that users know what to
expect when clicking on the items.
The sub menu for the services tab is exposed on every page on the
site apart from the home page. This isn’t a big deal but once you are
aware that it is there it’s a shame to see it missing from the home
page.
If you can try and consolidate some of your CSS and push the styles
into an external style sheet (either manually or using one of the
actions). This will help speed the site up as pages can use cached
styles.
All in all Jon this is a great looking, and functioning, site.
Very thorough and extremely helpful. I will certainly take on board everything you mention - add pages for times, look at the titling more closely.
Regarding the ‘services’ menu… I completely understand what you are saying and it has been a concern of mine. The submenu is actually there, but by having the carousel contained inline, it ends up hiding the submenu. I have tried a variety of different ways to counter this but in the end I had conceeded due to time constraints. Any tips are always welcome.
It should set the z-index of the navigation to above the carousel.
Thank you so much guys for taking the time to comment… it’s always good to know.
Tim you are a superstar! THANK YOU!! Putting in that extra bit of code did the job perfectly. Just one question… what on earth is z-index:1000? I now know what it does, but I always find it helpfult to understand the code I use incase I need to use it in the future.
Z-index is the third dimension of Cartesian (x,y,z) three-dimensional
space. Imagine that every element on your visible page is on a clear
pane of glass, parallel to the face of your display. Those panes are
numbered, starting at 0 for the body of the page itself and increasing
in number the closer they get to your eye. If the body has no
background-color, then you can even have negative z-indices and still
see those elements too.
Setting an item to an absurdly high z-index ensures that it won’t be
covered up by another element that appears later in the source code
order.
