Has anyone set up a Showcase slideshow on a mobile responsive site?
Normal images will have width at Fixed% and height at Flexible, but this doesn’t work with a slideshow, even when set to’Pass through’.
Slideshows are pretty standard these days, so something ought to work. Any ideas?
Duncan W.
I’ve been using AmazingSlider. OwlSlider & WOWslider are also a good options. All three are responsive.
Someone else more knowledgeable than I will have to help you answer your question more specifically about Showcase. I believe if the width must be fixed it is a no-go for responsive. Responsive layouts depend on flexible-width layout – that’s what makes it responsive.
Doty is correct on this one – Showcase is incapable of creating flexible, responsive-friendly, galleries. The options she listed are great, but I’d add Exhibeo to that list (which I think is the successor to Showcase).
