If you like the look of this slide on the apple site iPhone - Apple
Galleria has a similar version here http://galleria.aino.se/media/galleria/demos/dots-01.html
View the page source, it’s an easy setup but it is jquery so as you know there are possibilities for conflicts with other scripts you may already be using in Freeway ?.
Other Galleria options here http://galleria.aino.se/
You can do this in Freeway with the Carousel Action, just set the Auto-
scroll option to the number of seconds you want each element to pause
before animating to the next option.
